Sponsored by: CARiD
Torsion spring swap problem --2x4 vs 4x4
Old Jan 16, 2008 | 02:38 PM
kaptain's Avatar
I recently swapped a set of 7700lb torsion springs into my 2000 4x4 extended cab, short box F150 to accommodate a 4r100 tranny. The springs went in just fine, but now the front sits realllly low. It almost looks like the 2x4 ride height. Is the a difference in the 2x4 and 4x4 springs? could I have gotten 2x4 springs?
The part number for the bars that I have is:
Right torsion bar F65Z-5B326-HA
Left torsion bar F65Z-5B327-HA
Old Jan 16, 2008 | 03:17 PM
jreulet's Avatar
As far as i know, the 2wd's didn't have torsion bars, unless the 7700 was different.
Old Jan 16, 2008 | 07:35 PM
kaptain's Avatar
riiiiiiight... I forgot about that. damn. so has anyone else that has done the swap had this problem? I tried turning the spring to the next possible orientation but it wouldnt turn enough to go into the crossmember. Anyone else experience this problem?
Old Jan 16, 2008 | 10:59 PM
wandell's Avatar
I bet that is your problem. They make a tool to preload the torsion bars as you set them in the crossmember.
Old Jan 16, 2008 | 11:04 PM
Adam06FX4's Avatar
Registered User
if you dont have the tool to preload the bars then this is what you need to do. it has worked for me before. jack up the truck letting the suspension hang. then remove the front tires and disconect the lower ball joint. then have a buddy push the controll arm down even further untill you can get the adjuster plate it. let me know it it works for ya. also make sure you have the bars in right. they should be marked right and left.
Old Jan 17, 2008 | 01:22 AM
kaptain's Avatar
I had it at my mechanics shop (he was helping me out for free because he has the tool) and we couldn't get it to go with the tool. the idea of disconnecting the ball joint sounds like a good one. once you have the spring in though, how do you get the control arm back?
Old Jan 17, 2008 | 10:43 PM
kaptain's Avatar
bump.
Old Jan 18, 2008 | 12:33 AM
Adam06FX4's Avatar
Registered User
just put a jack stand under it and use the weight of the truck
