Sponsored by: CARiD
Wandell...you here??
Old Jan 15, 2008 | 08:33 PM
TN-F150's Avatar
Old Jan 15, 2008 | 08:51 PM
wandell's Avatar
Yep.
Old Jan 15, 2008 | 09:09 PM
TN-F150's Avatar
And anyone else too...
Hey, regarding the leveling kits. I see some guys using 2" AS and some using 2.5". I only see one kit on AS website and it is the 2.5". When using a 2.5" kit is anything needed for the rear or do these kits raise about the same so it truly levels it? Also, I read (can't remember where on here now) Daystar is making a kit like AS but with urethane...they don't show these on the site. And lastly, which one is better? I can see where neither should change the factory ride since it is going on top of the shock but is one better constructed than the other. Your thought??
Thanks Dude!
Old Jan 15, 2008 | 09:25 PM
thorherc67's Avatar
i had the 2.5 AS on my truck and my dad has the 2.5 daystar on his. and hey rode the same and both leveled the out perfectly. hope this helps
Old Jan 15, 2008 | 09:57 PM
TN-F150's Avatar
and of course anyone elses thoughts too... Thanks thor!
Old Jan 15, 2008 | 11:21 PM
glasco's Avatar
"Wandell" if i wanted to put a 3'' body lift on mine what sort of things should i change besides tire size of corse i was thinking about BFG M/T 35 and 16x10 rims like backspacing and torsion bar/adjustment? or if anyone has any advise
Old Jan 15, 2008 | 11:24 PM
keith_bennett's Avatar
I would crank the torsion bars and get an alignment. Your wheel backspacing should be 4.5". This is what i have and this will put your tires even with the fender flares.
Old Jan 16, 2008 | 08:59 AM
jk007's Avatar
That setup will be fine and look good. If you want to level it out, do what Keith said after you install the lift. Crank the torsion bars and get an alignment.
You may want to look at a programmer to make up for some lost power once you slap the 35's on, but it won't be absolutely necessary IMO, even if you have a 3.55... I ran this same set up on a 2000 SCAB (3"BL and 35s on a 3.55 gear ratio) and it wasn't the fastest thing on the road, but she was sufficient...
Other than that, pics of the install process are in my gallery, and check out the other 2 BL threads I just post one, for some things that might help you out.
Good luck and post some pics when you're done.
Old Jan 16, 2008 | 10:24 AM
TN-F150's Avatar
I think my thread got Hi-Jacked....Somehow it went from late model truck leveling kits to early model truck body lift and torsion bar adjustments...what the!... Anyone have anything to add on my "ORIGINAL" posted questions?? If not then I'll remove it from my subscribed threads and figure it out on my own.
Thanks thor for staying on topic...
Old Jan 16, 2008 | 10:26 AM
wandell's Avatar
I agree. I'd just crank up the torsion bars enough to level the truck and get an alignment. I'd use a 10 inch wide wheel with 4.5 inches of backspacing.
As for the leveling kit's on the 04-08, they all do the same thing and it's pretty hard to make a bad one.
Old Jan 16, 2008 | 02:03 PM
attworth's Avatar
I'd get the AS. It's cheaper and it's steel. Seems like urethane would wear out.
Edit: As far as 2" vs. 2.5", it just depends on how much lift you want. I'm not sure about the actual difference though. It'll differ on every vehicle.
Old Jan 16, 2008 | 02:51 PM
glasco's Avatar
sorry man just wanted to ask wandell a question
Old Jan 16, 2008 | 10:54 PM
wandell's Avatar
Yeah, every truck is differnt. Most new 4x4 owners say the 2.5 inch kit levels them while 4x2 owners say it leaves the nose high. If you are trying to run a larger wheel/tire combo, go with the 2.5 and then raise the rear with a taller lift block if you need to.
Old Jan 17, 2008 | 10:26 AM
TN-F150's Avatar
Talking
Ah, that's alright! I was having a crappy day yesterday and I shouldn't have reacted here about it. Wandell seems to be in demand...he's full of answers.
Actually everyone here does a great job of helping each other out.
Cheers to all...
Old Jan 17, 2008 | 11:58 AM
TN-F150's Avatar
Just a filler to bump me to 100
