Sponsored by: CARiD
Question: Bronco Lift?
Old Jan 15, 2008 | 03:39 PM
IDNC76's Avatar
i kno this is suspension forum for f-150s, but i figured i get some more replies in here. My friend has 1993 Bronco 4wd he already has 6in fabtech on it, it sags about an 1 or 2 in the rear. any way hes lookin for more lift, i kno he can do a 3in body lift, and he will but are there torison bars he can crank, or an leveling kit he can put up front. and then just put a bigger block in the back with a new leaf spring pack? i think overall he can yeild about 5 in. and wat size tire would be good with that combo of 11 in of lift 38s? any input greatly appreciated.
Old Jan 15, 2008 | 03:50 PM
4.2trimble's Avatar
im 95% sure that the front end of the 93 has coil springs and in most cases you can buy a coil spring spacer that will lift the front end around 2- 2.5" and for the rear you could do add-a-leafs (aal) or blocks, if your rear end is sagging the you might want to get a new leaf pack! or get a leaf pack that is made for the lift! check 4wheelparts.com
Old Jan 15, 2008 | 04:02 PM
IDNC76's Avatar
thank you for your reply , clears alot up for me thanks.
any idea on tire size?
Old Jan 15, 2008 | 10:57 PM
4.2trimble's Avatar
um just taking a very broad shot with this but 38's would look nice and with some trimming possibly 39.5? im not 100% sure but with that much lift you should beable to get 38's under it!
Old Jan 15, 2008 | 11:17 PM
4.2trimble's Avatar
he is running 11" of lift and 38.5s! but if you plan on doing that id upgrade your axles. his is a 89 but i think its the same set up
