Sponsored by: CARiD
Those that went from 2" to 2.5"
Old Jan 7, 2008 | 08:48 PM
mbogosia's Avatar
Registered User
I just went from 2" to 2.5" on my front leveling kit. I had the truck aligned when I did the 2", do you think it needs to get aligned again after the 2.5". I assume the answer is yes but just wanted everyones input.
Old Jan 7, 2008 | 08:49 PM
CRF250rider1000's Avatar
I would
Old Jan 8, 2008 | 02:09 AM
05FordFX4's Avatar
Just a quick question about the 2".
when you had the 2" on was the front end still higher than the rear like the 2.5" seems to do?
Old Jan 8, 2008 | 07:53 AM
051fdrof's Avatar
Your truck didn't sit level with the 2"? Others have posted that the late 2006+ trucks have 1/2" less rake, so 2" should do it.
Old Jan 8, 2008 | 08:09 AM
mbogosia's Avatar
Registered User
The 2" made it slightly higher in front so I then installed an Add A Leaf. That then caused it to be higher in the back again. LOL The 2.5" spacer with the Add A Leaf now has me exactly at 39" at all 4 corners. Keep in mind I have a 2wd.
Old Jan 8, 2008 | 08:41 AM
051fdrof's Avatar
4x2... that makes sense. 39" is right about where a 4x4 rear end sits.
Old Jan 8, 2008 | 09:31 AM
hivoltagefx4's Avatar
I've got the 2.5" on my '06 FX4 and it sits perfectly level!
Old Jan 8, 2008 | 09:36 AM
051fdrof's Avatar
Supposedly, trucks that were built late '06 and later that had 1/2" less rake. Maybe yours was an early build?
