Sponsored by: CARiD
NEW AS 2''lift
Old Jan 7, 2008 | 07:44 PM
tylerN's Avatar
NEW AS 2''lift
so i just got my new autopsring front end 2'' spacers. I measured the spacers and they were 1 3/4''. Are they supposed to be this length, i know its stupid but arent they supposed to be 2''. Also how hard are they to install.
Old Jan 7, 2008 | 07:56 PM
Jaderbutt's Avatar
Just installed the autospring 2" kit on my 07 4x4 supercrew last weekend, not a hard install at all. The only problem that I has was getting the lower control arm/strut assembly bolt back in. I did measure mine prior to install and it was also about 1 3/4". Make sure to get an alignment when your done!
Old Jan 7, 2008 | 08:46 PM
mbogosia's Avatar
Registered User
I just swapped out my 2" for a 2.5" and they barley look different. I didn't measure but it was a hair difference. Funny thing is it lifted my truck at least a 1/2" more.
Old Jan 7, 2008 | 09:16 PM
05RedFX4's Avatar
AS spacers are sized by how much lift they give, not how thick they are. By pusing down the LCA 1.75" you lower the ball joint by 2", kinda works like a class 2 lever. Hope my explination helps.
Old Jan 7, 2008 | 10:59 PM
f150monster232's Avatar
i had the same problem i bought a 3in kit and i measured 2in, but it gave me 3in in the end
Old Jan 8, 2008 | 10:29 AM
DIHLON's Avatar
The instructions tell you how thick the spacers are. I think it says the 2" is actually 1 5/8" and the 2.5" is 1 3/4". Install is simple. It took me a little over an hour doing it myself. The hardest part for me was hooking up the upper control arm ball joint to the spindle. I had to jack up the lower arm and use a pry bar on the upper arm to stab the balljoint.
Old Jan 8, 2008 | 03:26 PM
mhockey9090's Avatar
where can i get these as spacers from and how much thanks guys
Old Jan 8, 2008 | 03:55 PM
hoss66's Avatar
i have the 3 inch pro comp and it only measured 2 1/2". my pro comp was like 120 but you can get the as for like 90. ebay, www.ntwonline.com www.4wheelparts.com these are a few places you could look.
Old Jan 8, 2008 | 04:12 PM
just ordered my as 2'' today so its coming in next week sometime so thanks some of yall for your help on another thread
