My Lift/Tire Plan
My Lift/Tire Plan
I've got a 2003 F150 Flareside 4X4 extended cab with the 4.6 and auto tranny, 3.55 LSD. My plan is to put 33 inch tires on my stock Lariat 17 inch chrome rims, and I'm looking to bump the back of the truck up an inch by sticking in the Fab-Tech 3 inch blocks (removing the stock 2 inch blocks first). For the front, I'm looking at the AutoSpring 2 inch leveling kit. I want to make SURE there are no rubbing issues with the 33s on there, and I don't want to crank the torsion bars either. I also realize that the truck will still sit a little nose-down but I want it like that. Does anyone see a problem with anything in my plan? Will everything work well together? Finally, will I need to get my computer or anything reprogrammed for turning larger tires? Thanks.
You will need to get your speedometer recalibrated for the tires if you want the speedo and your mileage to be accurate.
Autospring doesn't make a leveling kit for your truck. You don't need one because the front ride height is adjustable via the preload on the torsion bars. You can buy a leveling kit, but it's just reindexed torsion bar adjustment keys which allow you to put way, way too much preload on the torsion bars. No need to pay $100 for something you can do for free. You can fit 33's on your truck without lifting it any using the oem wheels.
Also, you won't need to regear with 33's.
doesn't cranking the torsion bars affect ride quality? i don't mind spending $100 on a kit that's meant to bring the front up.
When you increase torsion bar preload, it makes the initial portion of the suspensions travel slightly stiffer. Some people love this, some hate it. You will have to judge for yourself. What we are saying is that a leveling kit does the exact same thing. The leveling kit (for torsion bar equipped trucks) manufacturers' claim that ride quality is not affected is an outright lie.
i was always under the impression that a leveling kit is a spacer that goes inbetween the coil/shock and the body mount. so if i were to buy a leveling kit, all it would be is a tool to crank my torsion bars?
i've also heard people talking about getting the computer/speedo recalibrated for bigger tires, one reason because the shift points of the auto tranny will not be the same and it'll eat up a tranny.... i'm skeptical, but is there any truth to this? is it an easy thing to have done at a dealership or whatever?
As far as messing up your tranny, never heard that. I always drive stick though so I don't know for sure.
Originally Posted by ocoffroad
He shouldn't even need the torsion keys right? I cranked up my torsions on my 01 ranger edge that I had and I believe it was a 10mm socket I used or maybe a 12.....
The re-indexing of the hex in the key in affect twists the bar without turning the bolt. In most OE keys you would come close to running out of threads on the bolt to achieve the lift.
