Sponsored by: CARiD
Adjustable camber bolts or not?
Old Dec 31, 2007 | 12:49 PM
DIHLON's Avatar
Ok i've been reading on here whether I need my camber/caster adjusted after installing my 2" level kit. From what i've read, it appears most alignment shops just want to hit you for the extra cash and you shouldn't need it adjusted. One guy even quoted from someone that works for Auto Spring that they've installed thousands of these kits and they've never had to adjust the camber/caster on one of them. He said the alignment shops are just trying to screw people. Did you guys have yours adjusted or just the toe-in/toe out?
Old Jan 1, 2008 | 11:21 AM
clar's Avatar
yes you need a alligment by lifting 2inches you pushed your camber out you could drive like this but most likely would notice tire wear
Old Jan 1, 2008 | 08:36 PM
wandell's Avatar
I think he is asking whether or not he needs adjustable camber bolts, which he probably doesn't.
Old Jan 2, 2008 | 01:15 PM
051fdrof's Avatar
My right toe was off 3/4" of a degree after my Quick Lift install. That's it.
Old Jan 2, 2008 | 01:31 PM
Copenhagen848's Avatar
The toe was adjusted, and you will need an alignment after a leveling kit install.
Old Jan 2, 2008 | 01:46 PM
051fdrof's Avatar
And yes, that was enough to warrant an alignment.
Old Jan 2, 2008 | 02:47 PM
DIHLON's Avatar
I know the toe will be off but i'm trying to figure out if a camber adjustment is necessary so the guys at the alignment shop don't try to screw me.
Old Jan 2, 2008 | 02:52 PM
Do they charge a flat rate for an alignment? If so, I don't see how they could screw you.
I'd try to find a shop that charges a flat rate if they don't.
Old Jan 2, 2008 | 03:02 PM
051fdrof's Avatar
x2. Hourly rate for an alignment is very unusual around here.
You might also want to consider that your caster/camber could have been off before you added your leveling kit.
Old Jan 2, 2008 | 03:23 PM
sog805's Avatar
The alignment shop should be able to adjust your camber/caster without you having to buy new ones. If they give you crap you should take your truck to another shop.
Old Jan 2, 2008 | 03:36 PM
DIHLON's Avatar
I was under the impression the newer fords don't have adjustable camber bolts which is why if the camber needs adusting, you have to buy adjustable camber bolts and the price jumps from $60 to $170.
Old Jan 2, 2008 | 03:59 PM
051fdrof's Avatar
You might be on to something... I just did a search and found several threads about this issue. One of the threads had a link to the cam kit and it's a lot less than $110.
Here's a link to the kit.
Old Mar 5, 2008 | 04:21 PM
NCSU_05_FX4's Avatar
Screw the alignment! Why would a company make a product that could end up causing damage to other components unless you make other adjustments? That's just silly, surely that type of company would go out of business.
- NCSU
Old Mar 5, 2008 | 04:30 PM
051fdrof's Avatar
Umm.. huh?
Old Mar 5, 2008 | 04:45 PM
clar's Avatar
Sears $69.00 no new cam bolts needed ................
