Sponsored by: CARiD
Daystar 2.5" leveling kit
Old Dec 13, 2007 | 11:19 AM
Chris FX4's Avatar
I am in the process of purchasing a new leveling kit to fit larger tires.
What is the best one to go with?
The place where I am purchasing the tires uses the Dayster 2.5".
Has anyone had experience with this kit?
If so, Have there been any bad experiences with it?
Old Dec 13, 2007 | 11:24 AM
BGF150's Avatar
i have had no problems with it, its a great kit! im assuming your truck is a 4wd, the general rule of thumb around here is if you keep your stock rims you can fit up to a 35" tire but if you go with aftermarket rims you should stick with 33" inch tires due to backspacing.
Old Dec 13, 2007 | 04:10 PM
wandell's Avatar
I agree. There is nothing wrong with the Daystar kit, but the one piece spacers like the Autospring are much easier to install.
Old Dec 13, 2007 | 06:39 PM
JD790's Avatar
x2. Don't have to compress or remove the coil spring using the Autospring kit. Just install on top of the exisiting strut assembly and get a front end alignment and you are good to go! Doesn't effect ride quality either - not sure if the daystar does or not.
Old Dec 13, 2007 | 09:22 PM
attworth's Avatar
I agree.. Go with Autospring. Much cheaper, easier..
