Sponsored by: CARiD
5inch block vs AAL
Old Dec 2, 2007 | 11:06 PM
fiveoh108's Avatar
Question 5inch block vs AAL
I have the 6 inch Fabtech lift and just ordered a 2" autospring spacer. Now for the rear, which is best a 5" block, or keep the 3" block that came with the fabtech lift and add a leaf. I do not do much towing, minus my boat in the summer time? What do you think?
Old Dec 2, 2007 | 11:51 PM
nooq's Avatar
Thats gunna be 8" of lift in the front, id go 5" block in the rear and a 2" AAL to put ya level. I have a new 2" AAL if you are interested...let me know, inooqz@hotmail.com
Old Dec 3, 2007 | 12:19 AM
thorherc67's Avatar
i'd go with the 5 inch block and see if you like it and if not an AAL
Old Dec 3, 2007 | 12:34 AM
fiveoh108's Avatar
My rationale was, i am adding 2 inches in the front, add 2 inches in the rear with either the block or AAL. If i do both wont i be adding 4 inches to the fronts 2?
Old Dec 3, 2007 | 12:37 AM
thorherc67's Avatar
No i have a 2wd and i am looking at the same setup i would do the 2 inch up front and put a 5 inch block in the rear, the back of your truck should sit about an inch lower in the rear
Old Dec 3, 2007 | 12:40 AM
fiveoh108's Avatar
is there a ride quality or safety is issue with a 5 inch block or an AAL..and where do i get a 5 inch block? I have seen AALs around, but not 5 inch blocks.
Old Dec 3, 2007 | 01:26 AM
bud8817's Avatar
wait untill you do the front and then measure the front and the back back see how bad the rake is then decide what you need. i would not buy a AAL your ride dwill turn to ****. your probably going to be fine with a 5" block.
Old Dec 3, 2007 | 12:43 PM
djh1121's Avatar
Call Fabtech, if you get right person on the phone they can hook you up. If you get the wrong person just call back in a few.
Old Dec 3, 2007 | 05:45 PM
nooq's Avatar
yea go directly through fabtech.
