Suspension Problems 6in Pro Comp On 2.5 Spacer Frotn Cv Binding
to reclock the driveshaft: normaly (stock) the driveshaft looks something like this: >====-- or in other words the u-joint opening are "opposite" and you need to take out the shaft... take off the boot, and pull it apart. Your goal is to turn one end 90 degrees so it now looks like >====< . to do this you will need a dye grinder (or some other slim grinding wheel) to grind down one of the keys in the slip yoke. Sorry for the lack of discription... not feeling it right now. But the FABTECH instruction tell you how to do this with a pic or two think. http://www.fabtechmotorsports.com/pd...on%20Sheet.pdf
And to FoMoCoFan17: sorry bud, I did hear ya, and you do bring up a valid point. I think we were just trying to correct the more eminent problem, the stacked spacers. The O.P. then wanted to know the best way to fix his C.V. and ball joint angles. I will agree with you that the noise he is hearing and saying to be the "c.v. binnding" might very well (and most commonly with Pro-comp) is the driveshaft not being reclocked.
Originally Posted by SHORTY2179
In the instructions it was saying that it will need re-balanced. Is that true or just something that they suggest?
You've Been Alot Of Help And I Really Appriciate It. In My Pro Comp Instructions It Doesn't Say A Thing About Cutting Out That Key. I Do Hope It Works I'm Gonna Do It At Work Today Maybe I'll Let U Know How It Goes.
Originally Posted by MercedesTech
(welcome to the site!) and do you have the stage one procomp lift with the big ole spacer up front? If so, it just really isn't a good idea to be stacking spacers. If this is the case... maybe look into some aftermarket coilovers that you can crank up to get the lift your looking for.
Originally Posted by Back in Black
Not trying to highjack forum....just curious MercedesTech what kind and how much lift do you have in your truck? I like the way yours sits not too big not too small.
