Sponsored by: CARiD
tires rubbing
Old Nov 23, 2007 | 03:52 PM
bone79's Avatar
hey wandell they are rubbing on the back part of the fender starting to take the paint off too. i'll see if i can get a pic
Old Nov 23, 2007 | 05:25 PM
bone79's Avatar
hey wandell, here are the pics!
Old Nov 23, 2007 | 08:47 PM
awmllc2000's Avatar
now thats what i call RUBBING!
Old Nov 23, 2007 | 09:23 PM
bone79's Avatar
wandell, the passenger side is alot worse than the drivers, for some reason.
Old Nov 23, 2007 | 11:34 PM
luckythirteen13's Avatar
are you sure you got a 6" lift. the way those tires are fitting it looks like a 4"
Old Nov 23, 2007 | 11:56 PM
acm8705's Avatar
I still think your problem is the backspacing of your rims. If your tires were tucked further into the wheel well they wouldn't rub on that spot.
You could possibly take care of the rubbing and keep your rims by getting coil overs and cranking them up for another 2" of lift.
Old Nov 24, 2007 | 12:01 AM
bone79's Avatar
yeah it's a procomp 6" lift
Old Nov 24, 2007 | 12:02 AM
bone79's Avatar
how much do the coilovers run?
Old Nov 24, 2007 | 10:25 AM
wandell's Avatar
Yeah, no doubt. The rubbing is caused by a combination of the 10 inch wide wheel and shallow backspacing. Just guessing, by the amount those wheels are sticking out, I'd say you have about 4.5 inches of backspacing. If you went to a 9 inch wheel with 5 inches of bs (which is the most common wheel spec), it would pull the tire inward and eliminate (or at least lessen) that rubbing.
Old Nov 24, 2007 | 11:42 AM
bone79's Avatar
thanks wandell and acm8705 for all the help!
wandell and acm8705, will a 10" rim work with the correct backspacing( what would that be a 6"), or should i just go with a 9"?
Old Nov 24, 2007 | 03:57 PM
wandell's Avatar
It will be easier to find a 9 inch wide wheel with 5 inch of bs as they are very common. The only 18x10 with 6 inch of bs that I know of is the Mickey Thompson.
Old Nov 24, 2007 | 05:37 PM
bone79's Avatar
you know any for 20's, is that what i need 6" of backspacing? thanks
Old Nov 24, 2007 | 08:03 PM
wandell's Avatar
Sorry, I had 18's on the brain for some reason. Check 4 Wheel Parts website. The KMC and Moto Metal wheels have a couple different bs options in your bolt pattern.
Old Nov 24, 2007 | 08:18 PM
clar's Avatar
You dident say were they were rubbing , I have a 6" Lift with 35s on 8" rim had to cut the vallance about a 1&1/2" to clear the tire other than that no problems
Old Nov 24, 2007 | 08:26 PM
wandell's Avatar
His pic shows them hitting the back of the wheelwell and fender flare.
