Sponsored by: CARiD
U-Bolts
Old Oct 26, 2007 | 02:44 PM
ranorris2's Avatar
U-Bolts
I ordered 5" Blocks for my truck expecting it to come with the required U-bolts, and it didn't. So now the back of my truck is sagging What size U-Bolt are you guys using that have the 5" Fabtech Block?
-Ryan
Old Oct 26, 2007 | 02:52 PM
nooq's Avatar
-Ryan
you can find a spring shop locally and tell them the length block you are using. they can bend them and tap them right there for you. not hard at all. at is pretty inexpensive, usually 40-45$.
Old Oct 26, 2007 | 02:54 PM
Jditta's Avatar
I'm assuming you have a lift on already. If you do you can use the U-bolts on there from the lift with the 5" block thats what I did. Or do what nooq said and go to your local 4x4 shop and they can get you some.
Old Oct 26, 2007 | 03:09 PM
ranorris2's Avatar
Yes I already have the lift on my truck. I have a 2wd so the lift came with 2" blocks. You think those U-Bolts will work? I will have to try it I guess. If not I will do what nooq said. Thanks guys.
Old Oct 26, 2007 | 03:13 PM
Jditta's Avatar
I'm not sure, I have a 4x4. So I'll leave this one up to nooq
Old Oct 26, 2007 | 05:25 PM
°°Pat°°'s Avatar
Look at how much thread you have left with your current u-bolt.
You should need close to 3'' to fit your 5'' block.
Old Oct 26, 2007 | 05:27 PM
crash_lucky13's Avatar
tsk tsk tsk. sounds like a bad sales rep.
damn
tuesday?
Old Oct 26, 2007 | 09:32 PM
a7x_nocturnal's Avatar
Go to autozone or checker or what ever auto parts store..they have a lift/lowering U-bolt set...$20 bucks and should be long enough..I ahd to cut mine down about 3 in... same with the race truck.
Old Oct 27, 2007 | 11:27 AM
ranorris2's Avatar
I went to autozone and oreillys, neither of them had them in stock and they could not order any. But I got it taken care of, I ordered some yesterday, should be here tuesday. Then I can finally post some pics of my truck lifted
