Autospring install ?
Hey guys I just installed the 2" AS. My question is that, I tried to remove the lower nut from the sway bar and all it did was spin after I broke it loose. After that I decided to unbolt the top of the sway bar link instead, which worked out much better. Now when I tried to tighten the lower bolt it just spins and does not get tight like it was when i first turned it. I assume this is not a problem since all it did was spin and never came loose but thought I would check just in case.
I did the same thing as you. The problem is the lower link has a connection similar to the upper control arm. I ended up loosening the lower link about a half turn and drive for a day or two with it like that before figuring out what I had done. Use a two wrenches to tighten it. One on the nut one on the bottom of the link shank - you will notice it is not threaded.
Aaron
Aaron
