Sponsored by: CARiD
1993 F150 alignment problems
Old Sep 3, 2007 | 01:45 AM
bryanc1's Avatar
Unhappy 1993 F150 alignment problems
Anyone had problems getting thier alignment correct? I have a 1993 F150 XLT short bed w/5.8L. I have had it aligned 2 times and it still will not steer correctly. At about any speed when I go to make a "correction" on a straightaway, the slightest turn of the wheel causes the truck to weave as if I had over corrected. At low speeds this is not too much of a problem, but at highway speeds this makes the truck feel very unstable and hard to drive. I thought that maybe the rearend had slid over or something but it measures out centered to the frame. I did notice that the frontend seems to be offset to the right. The toe is correct as far as I can tell, and I don't see anything that looks bent. Any ideas?
Thanks!
Old Sep 3, 2007 | 12:53 PM
andrewc_11890's Avatar
Have you had it professionally aligned lately?
Old Sep 3, 2007 | 01:04 PM
kingfish51's Avatar
Have you checked ball joints, tie-rod ends, etc. That old a vehicle some are bound to be worn and if they are, you can align every day of the week, and it still will not be right.
Old Sep 3, 2007 | 01:35 PM
bryanc1's Avatar
Red face Everything looks good
I had it aligned 2 times at a local shop. I have checked all ball joints, bushings , linkage etc. and everything seems tight.
