Started on it today
I started on the body lift today. Right of the bat i ran into trouble, one of the bolts for the rear bumber was turning inside, so i had to cut it off.
[IMG]
[/IMG]
[IMG]
[/IMG]
The front bumber came off with no problem at all.
Then i started on the bed bolts. The first five came out alot better than i expected. The last one took a grinder and a few choice words to get it loose
One question i do have is where do all of the plastic blocks go? I could only find 4 places on the cab and six for the bed. Where do the other six go?
[IMG]
[/IMG][IMG]
[/IMG]The front bumber came off with no problem at all.
.One question i do have is where do all of the plastic blocks go? I could only find 4 places on the cab and six for the bed. Where do the other six go?
Those are probably extra for different cab/bed configurations, but I think there's eight for the cab even on a regular cab. Six inside the cab and two FESM mounts (front end sheet metal) up by the radiator support.
Just look under the truck at the frame for all the body mounts. Every bolt that holds the body to the frame needs a spacer.
Wandell, which bushing do you have to drill out? The one's up at the very front have a funnel shaped part, do you drill it out and if you do how does it fit in the lift block?
just shake it
and try turning it back and forth with some pressure, it has to go straight back, not at an angle so take that extension off so you can straighten it out with more room to work.
[/IMG]
