Sponsored by: CARiD
Which block?
Old Aug 27, 2007 | 04:34 PM
ThumperMX113's Avatar
Originally Posted by BullRing
Ya but the center of gravity is lower!
LMAO! Do you think the difference in having the rear of the truck level with the front and not doing so is going to save you from a roll over? It's not and thats coming from someone who's truck sits 2" lower in the rear. I guess now we're worrying about our center of gravity when lifting a truck? It doesn't make much sense, since you're LIFTING your truck. Of course the center of gravity is going to be higher. Just like I said, what about stock trucks? They sit 2" higher in the rear. Figure that one out in your whole scheme.
Old Aug 27, 2007 | 04:46 PM
BullRing's Avatar
Ya and stock trucks have a very low center of gravity.....I'm saying it's better to leave the truck they way the lift comes cause that thew way the made and tested.......Given the right conditions you can flip........So lift the back end of a lifted truck higher than the front........In his case he was going down about 10 degree hill someone jacked there breaks on infront of him to make a turn and he did the and flip it.
Old Aug 27, 2007 | 04:55 PM
A 10 degree hill!? LMAO! Sorry, I don't buy it. I'm done with this because apparently you're completely insane when it comes to this matter.
Old Aug 27, 2007 | 04:57 PM
051fdrof's Avatar
The question is if the flip could have been averted if his truck was level, and that is impossible to prove without an analysis of the crash data.
Old Aug 27, 2007 | 05:03 PM
i.ride.suzuki's Avatar
BullRing: please do us a favor and remove your head from your anus. The truck will skid before it flips over, unless you use God as your brakes.
I can't stop laughing, just imagine... it isn't everyday you see a truck do a front flip.
Old Aug 27, 2007 | 05:12 PM
BullRing's Avatar
Your funny.............well this was a fun way to pass some time.......need to head home......see ya!
Old Aug 27, 2007 | 05:13 PM
jiggle's Avatar
What in god's name are you talking about? Are you saying that because the truck is lifted more in the rear, then the COG is lower and the truck is prone to flipping end over end? That defies all laws of physics and my common sense...
Old Aug 27, 2007 | 05:16 PM
Not to mention you've got GM guys laughing at you too. I guess we have something in common, we all think you're an idiot.
http://www.gmfullsize.com/forum/showthread.php?t=92439
Old Aug 27, 2007 | 05:18 PM
FoMoCoFan17's Avatar
Old Aug 27, 2007 | 05:21 PM
jiggle's Avatar
Not to mention that lifted trucks generally have bigger tires, which decreases the brake's efficiency. I would love to know what brake/tire combo this guy had. Not only were the brakes applied so hard that the truck flipped over its nose, but the tires didn't lose traction in all of this. I know that no matter how hard I step on them, my brakes will never even come close to locking up my 35s.
Old Aug 27, 2007 | 10:19 PM
He probally had a custom calipers and rotors off of a Bugatti with BFG G-Force tires. It was all custom!
Old Aug 27, 2007 | 10:25 PM
patshea098's Avatar
HAHAHA
thump this is what we need.....i mean with out trucks sitting so high and the off roading we do...we wouldnt want our 45K trucks and our lives gone......
Old Aug 28, 2007 | 02:24 AM
baja150's Avatar
What I'm saying is you have 5000 LBS. of truck lifted in the air and the rear of the truck needs to be little lower so if you have to stop suddenly (espcailly at a high rate of speed) your truck doesn't do a cartwheel. If you lift the back end up your not allowing for that resistance. The lower end gives you that. I'm all for lifting but if the lift kit company wanted the kit to be altered they would of made it the way he's looking to do. I just wanted to bring it to someone attention. The nieghbor down the road flip his truck due to adding a higher rear blocks in order to make his back higher on his lift kit.
Sorry man, but that's just not true. I'm a crash safety engineer at Ford and we crash test our vehicles at all different pitches to simulate vairious extreme situations (brake pitch, trailer lift, etc.) and there's no chance of a F-150 doing a cartwheel even in 99% of real life crash situations let alone simply emergency braking.
