Sponsored by: CARiD
Body lift or Spring
Old Aug 14, 2007 | 11:05 PM
hutch5.4's Avatar
Body lift or Spring
Unno if that is the prop are word "spring" but which is a better lift? In your opinion.
Old Aug 15, 2007 | 12:55 PM
wandell's Avatar
It depends. Body lifts are inexpensive but you are limited to 3 inches of lift. Suspension lifts are more expensive but you can go much taller. Nothing wrong with either.
Old Aug 15, 2007 | 01:56 PM
keith_bennett's Avatar
If you just wanna stick 35s under it, definitely a body lift. If you want bigger than 3 than suspension. Both are good kits. If you want a body lift, performance accesories is the best. If you want a suspension the best kits are rize, rcd, rancho, or fabtech, depending on what truck you have.
Old Aug 15, 2007 | 07:27 PM
nooq's Avatar
there is nothing wrong with the pro-comp lifts. Take it from someone that owns one, and not someone that hasnt.
Old Aug 15, 2007 | 08:08 PM
hutch5.4's Avatar
See i have this thing were im scared im going to get stuck b.c of the housing (where you gears are located) is to low. With a body lift you cant get the housing up higher correct?
Old Aug 15, 2007 | 09:38 PM
I didnt say those were the only good ones. I said they were the best. Your right nothing is wrong with pro comp, it just isnt as good as a rcd or a fabtech.
Old Aug 15, 2007 | 09:48 PM
hawaiian boy's Avatar
Brah! bodylifts cheaper and you'll fine some leaning also when hittin' the curves. So Brah, try suspension lifts.
Old Aug 15, 2007 | 09:52 PM
There is nothing at all wrong with body lifts brah.
Old Aug 15, 2007 | 10:31 PM
jb27's Avatar
Hutch,
(and others, correct me if i'm wrong) The casing housing the gears will be the same height regardless of whether you go with a suspension lift or a body lift. The only way you'll raise that is with bigger tires.
As for suspension vs. body, from what i've read, it seems that if you do a good bit of off-roading, the suspension is the way to go. They are definately more expensive, but if you have the means, go for it!
I was tight on $$ and don't do much off-roading, so i went the body lift route. After it's all said and done, I am glad i didn't spend the extra $$ for a suspension, the body lift looks fine (IMO). By going that route, I was able to get a few other things (tires/wheels/bull bar/tuner). Just depends on your $$ and if you want to do it all at once or piece by piece.
Depending on what year your truck is, if you go the body lift route, I would suggest an Autospring Leveling Kit to bring the front end up (for 2004+ model). All said and done, this will lift your truck roughly the same as a 6" suspension lift would. If you have a pre-2004 model, I think you can crank the torsion bars to produce the same effect as the leveling kit.
Old Aug 15, 2007 | 11:46 PM
02XLT4X4's Avatar
Body lifts just raise the body and its contents, a suspension lifts raises the frame and power train as well, so by all rights the body lift truck should handle better. Not that I go out of my way to set speed records but I haven't noticed much of a difference on my Ranger from stock.
Old Aug 16, 2007 | 02:03 AM
hutch5.4's Avatar
Yeah thats what i kinda figured on the housing part. Right now im just thinking about a leveling kit and some tires , i just wanted to get some opinions , im no expert on this truck thing.
