6inch Susp. & 3inch Body
Whats the biggest tire I can run with a 6inch supension and 3inch body?? What size gears will I need?? I already have the 3inch body and its not high enough. I want to go bigger. Are any of you guys with this setup satisfied with the height?? Pics would be great. By the way it is a '99 4x4. Thanks
38"-15.5" is as big as you can go with a 6" and 3" body, 4.88 would put you closest to stock gearing (alittle over but that is better to get the mass moving) you will have to do some triming to get them to fit but that is normal. good luck
