Sponsored by: CARiD
10in lift
Old Aug 10, 2007 | 06:58 PM
Redneck_Ford's Avatar
10in lift
who makes a 10in. lift for a 2007 fx4 ford f150? and what are the biggest tires i can run?
Old Aug 10, 2007 | 07:00 PM
wandell's Avatar
Check out the Rize lifts.
Old Aug 10, 2007 | 07:55 PM
i only see 8 and 12.
Old Aug 10, 2007 | 08:44 PM
Go 12"...
Old Aug 10, 2007 | 08:47 PM
Big_jts's Avatar
No one has one for a new body style F150. Only 8,12, and 14. Now you can do an 8" with 3" body or your own customizing with an 8" and stack a spacer. (not recommended but people do it) Why just a 10? Whats so demanding about a 10"?
Old Aug 10, 2007 | 08:52 PM
Big_jts's Avatar
Full throttle makes a 9.5" they claim will run 38's. Probably cost you around 4g's.
Old Aug 10, 2007 | 08:54 PM
i most likely will be getting a 8 but i was just researching about the 10. i dont want body lifts or spacers.(weakness). 12 would be to big especially for my first lift.
Old Aug 12, 2007 | 11:23 PM
fordfanatic32's Avatar
You could just get the rize 8 in. lift then put a 2 in. spacer on it. If u really had ur heart set on 10 inches.
Old Aug 13, 2007 | 09:38 PM
Could i put bilstein shocks on it to raise it some? Which kind if so?
Old Aug 19, 2007 | 08:11 PM
f150monster232's Avatar
Im donna go with King resys on mine and crank them up, ur able to crank them up a full 3ins witch would be the max you would want to do anyways if that
Old Aug 20, 2007 | 12:24 AM
Toyz's Avatar
I have a 6" fabtech (add a leafs and air bags in the back) and cleared 37/13.5's (-25mm offset wheels) with some very minor fender cut outs (just the plastic). I get full turning radius, and about 95% suspension travel before they rub on a turn. But i dont go off road much, nothing technical. oh and i dont think the shocks will give you much extra height. Your height i believe is mostly in the leafs and front torsion, along with the lift and things but the shocks just cushion....i think, someone help
Old Aug 20, 2007 | 08:38 PM
depends on the model of the truck 97-03 have T-bars and new 04-07 have coil overs which will both make ur truck higher
Old Aug 25, 2007 | 07:34 PM
ATOM's Avatar
its for a 07 fx4 according to his 1st post
Old Aug 25, 2007 | 07:52 PM
Omegasport20's Avatar
Well I am fairly new to trucks n lifts but I know Rize makes a 8" and a 12" kit. Tires I am not sure though I have seen 37s on a 6" lift so I would imagine that you could go much bigger. The offset of the wheel might run into problems if you have a wider rim. Not an expert yet.
Old Aug 25, 2007 | 07:59 PM
BullRing's Avatar
Get The 8" Rize And Add 2" Spacer But Then You Have To Bring The Rear Up With Blocks.
