Sponsored by: CARiD
Stock vs 6inch
Old Aug 5, 2007 | 05:49 PM
Devin4X4's Avatar
Stock vs 6inch
Hey guys... does anyone have any pics of a 6inch lift along side a stock height? I saw a 6inch the other day and boy did it look huge compared to mine. Didnt think they were really that much bigger.
Old Aug 5, 2007 | 05:51 PM
keith_bennett's Avatar
A 6inch will tower over a stock f150.
Old Aug 5, 2007 | 06:33 PM
mSaLL150's Avatar
6" suspension lift gives you 6 more inches. Say stock you ran 31 inch tires, and with the 6" most liekly running 35s. thats 4 inches more of tires, 2 of which are under the axle gives you another 2 inches. so the frame on a 6" lifted truck on 35s will sit ~8" higher then the frame on the stock rig, depending on which lift kit is used it can vary an inch or so.
Seth19's Avatar
Yea 6 in will tower over the stocks, which is why you need to go with a 8" or 10" so it will skyscraper over stocks! Just think about this, if you had 31" tires on a stock truck and added a 6" lift with 35" tires, thats 10" taller than stock. It doesnt seem like much but it is!
Old Aug 5, 2007 | 07:58 PM
KansasJoe's Avatar
You'd actually be 8" taller than stock because 35" is the overall diameter and the sidewall increases by 2" all the way around giving you a 4" taller tire but actually lifting the vehicle 2" because it's 2" taller on the top side as well.
Old Aug 5, 2007 | 08:32 PM
Seth19's Avatar
Ah ok, thanks for the info. I learned somethin today!
Old Aug 6, 2007 | 10:41 AM
ameration's Avatar
I have the 2.5" AS Leveling Kit and 1.5" AS AAL on my truck with 35's and mine sits about 4.5" higher than when stock. I got 2.75" from the 2.5" AS hit and another 1.75" from the 35's.
Old Aug 6, 2007 | 08:53 PM
xXDroneXx's Avatar
<a href="http://tinypic.com" target="_blank"><img src="http://i10.tinypic.com/68k1i5g.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old Aug 6, 2007 | 09:52 PM
dvsrider21's Avatar
here ya go
Old Aug 6, 2007 | 10:39 PM
Seth19's Avatar
Originally Posted by dvsrider21
here ya go
Is that a 2wd beside it?
Old Aug 6, 2007 | 11:39 PM
ThumperMX113's Avatar
I believe they both are 2WDs.
Old Aug 6, 2007 | 11:45 PM
Yep they are
Old Aug 7, 2007 | 12:11 AM
dvsrider21's Avatar
a lifted 2wd will sit the same height as a lifted 4wd with the same kit, correct?
Old Aug 7, 2007 | 12:13 AM
Incorrect, it will sit lower. I believe 2 inches.
Old Aug 7, 2007 | 09:35 AM
baja150's Avatar
Right... a 4X2 is about 2" lower than a 4X4, so when you put a lift on either one you make the 6" over stock.
6" = 6" almost every day of the week.
