4x4 height vs 4x2
No, because the stock height of a 4x2 is lower than the stock height of the 4x4 so it 4 inches off of that stock height. So when u put the 4 inch lift kit on the 4x2 its still goin to be allittle shorter than the truck with the 4x4 if that makes sense.
Yes they should be pretty close to the same height. a 4x4 is about 2 inches taller than a 4x2. 4 inch on a 4x4 plus the two inches it already had equals six. A six inch on a 4x2 would be the exact same height or close to it
Well if the 4" and 6" kits both provided a true 4" and 6" of lift then yes, but I think I remember some of the Rancho owners posting that their 4" lift actually lifted the truck 5" or so. If that's true then the 4" Rancho 4X4 would be slightly higher than the 6" 4X2.
Yeah isn't the factory height difference in the front coil springs...
Cause if I remeber correctly you can put the 4x4 springs on a 2wd and it will sit like a factory 4x4, so in that theory these lift kit manufacturers are NOT going to make a 4x4 coil for the 4x kits and a 2wd coil for the 2x kits...
Every thing should be the same other than the drop down brackets, shocks, and some other brackets but not the spring...
Somone correct me if I'm wrong...
Originally Posted by chris1450
acording to the 07 sales brocher the 4x4 is only .5 inch taller than the 4x2...
