Sponsored by: CARiD
Fabtech 6" for 2WD Question
Old Jul 24, 2007 | 07:59 PM
stud_135's Avatar
So fellas...on the 6" fabtech suspension lift for an 06 2WD will i run into the problem of the front being higher in the back...will the kit come with a bigger block because of the lack of any kind of block in the back of a 2WD? Also will the spacer kit and a coil over kit have any difference in the height of the truck...or is the coilover just for offroad performance? Any help would be appreciated...thanks guys
Old Jul 24, 2007 | 08:17 PM
volcom66's Avatar
yeah you can get 5 inch block or add a leaf to make up the difference. you have coil overs already so i dont know exactly what ur askin...if u mean the dirt logics upgrade they just give you new ones instead of ur stock...
Old Jul 24, 2007 | 09:50 PM
ThumperMX113's Avatar
The front isn't a spacer kit? Thats ProComp. The Fabtech comes with new longer shocks with a spring seat built onto them in which you use the factory spring. I'd get a AAL and call it a day.
Old Jul 24, 2007 | 10:59 PM
stud_135's Avatar
Yeah sorry im still kinda new to this...the dirt logics, would they give any extra lift? The reason i ask is because i have seen different two wheel drive lifts of the fabtech with what i thought was a different end result...i was just wondering...i am gonna go with fabtech so i guess i need not worry about the spacer....what size of block comes with the 2wd fabtech kit?
Old Jul 25, 2007 | 12:21 AM
wxscpo's Avatar
The 2WD kit comes with 2" blocks, you can either replace the 2" block with the 5" block or an AAL. I have the 5" block in the back of mine and have no issues with it. I have the basic Fabtech lift on my 2WD truck and don't think I need anything else since my truck will never go off roading.
