Sponsored by: CARiD
AAL question
Old Jul 23, 2007 | 10:55 AM
tex_n's Avatar
AAL question
I have a 06 Screw 4x2 with AS 2.5 in the front. Truck is nearly level, maybe 1/2 inch higher in the front, but not noticeable. I'd like to add a leaf in the rear to compensate for pulling a trailer and "junk in the bed" sag. All of the AAL's I see say 1.5 - 2 inches of rear lift. I like the level look....or close to it. Anyone know of an AAL that will not raise it that much? Any thoughts?
Old Jul 23, 2007 | 10:36 PM
speedfreak's Avatar
Helper Spring?
dbl post...
Old Jul 23, 2007 | 10:39 PM
speedfreak's Avatar
Helper Spring?
This should give you a little extra carrying capacity w/o increasing ride height.
http://www.suspensionconnection.com/...scon/1510.html
Old Jul 24, 2007 | 07:33 AM
baja150's Avatar
Keep in mind the thickness of the AAL itself is about 1/2 - 3/4". Even if the AAL was perfectly flat and provided zero lift from it's arch, it would still raise the truck about 1/2 - 3/4".
Old Jul 24, 2007 | 07:35 AM
tex_n's Avatar
Those helper springs just may be the ticket, thanks! On the other AAL's, is it possible to get just 1/2 in to 3/4 inches? All of the ones I see say 1.5 to 2 inches... Maybe short add a leafs??
Old Jul 24, 2007 | 12:39 PM
baja150's Avatar
You missed my point. An AAL that only raised the truck 1/2 - 3/4" wouldn't really be an AAL... it would just be a 1/2 - 3/4" lift block.
No I don't know of any.
Old Jul 24, 2007 | 02:17 PM
tex_n's Avatar
Ah, got the point now! Thanks!
