Sponsored by: CARiD
Removed Extra Leaf Spring, Alignment Now?
Old Jul 20, 2007 | 08:38 PM
dapro's Avatar
My 99 had 1 extra leaf spring, I compared it to a couple other trucks just like mine to figure which spring was added, I finished pulling them earlier today , I am happy with the drop in the rear, but I notice some vibrations on the test drive I haven't had before....I crawled under the truck and double checked all the bolts when I got back....all tight...
Should I get an alignment now, I don't see anything that changed, but I want to make sure....
How is the rear aligned, I mean what is adjusted, if at all?
BEFORE
AFTER
Old Jul 20, 2007 | 10:55 PM
wandell's Avatar
It sure wouldn't hurt to have it checked.
Old Jul 21, 2007 | 11:55 PM
dapro's Avatar
What would or could they adjust if it was off?, just curious....
Old Jul 22, 2007 | 10:21 AM
wandell's Avatar
I wouldn't think lowering the rear such a small amount would affect anything up front, but you never know. I wouldn't think the toe or camber would change, but the caster might.
Old Jul 22, 2007 | 10:30 AM
dapro's Avatar
ok so nothing in the rear would or could change? But it could effect the front end alignment right? Thanks for your help....
Old Jul 22, 2007 | 05:46 PM
wandell's Avatar
Right, the rear should be fine. I'm not positive about it affecting the front end alignment.
Old Jul 23, 2007 | 12:22 PM
EBROTEN's Avatar
Your pinion angle might be off now that you have lowered the rear. The vibration is most likely coming from your driveline.
