Question on Body Lift and Tires
Alright, so I want to get some lift out of my truck and fit larger tires. The thing is I don't want to dump a ton of money into it on a suspension lift when I probably will never go off-roading with it. Plus you never know how long you will have a vehicle for and it is a 2000, but with pretty low miles.
Anway I am thinking about getting a PA 3" body lift and to save on money just running larger tires with the stock 17" wheels. I know alot of people are running 35's with the Body Lift so that is possible with it leveled out and all.
I am thinking about Toyo Mud Terrains. Can I fit a 35X12.50R 17 on my stock wheel? That is the smallest size they list for a 17" wheel on their website.
Originally Posted by Russ47
yea u can fit 35x12.50x17 tires np with the PA 3" body lift
I have never had any rubbing, but i had to trim a little on the lower valance. Not a big deal.
I think it will rub.
FYI - I have a 6" Lift on my Screw and I added 315/70/17 and they rubbed when I made sharp turns in eitther direction. I did some minor trimming and that took care of it. Imho, be prepared to trim a little.
blksunshine
blksunshine
Cool thanks for the advice. Actually I just saw a pic of a truck on here, same exact style as mine....sames wheels, etc. only not an extended cab...and it has a 3" PA body lift and 33" inch Mud Terrains on the stock wheels. Doesn't look too bad either with the 33's.
https://www.f150online.com/galleries...1153&anum=1872
Are those 33" Muds or are those the 305/70/17 which is a 34" tire?
There are several people on here and over at Ford Truck World that have 3" body and 35s. Shewolf has an '02 screw with a 3" body on 35/12.50/17 Toyo MTs on factory 17" FX4 wheels. It looks real good.
Shane
Shane
Did you guys that have the body lift do anything to level out the front of your trucks to make the 35's fit better? or did you just do the body lif tand still have the slight sag in the front and they fit?
I cranked up my torsion bars to level my truck. I was afraid of rubbing when I went to 35's, but all I had to do was trim a little more plastic off the front bumper's valance. I have pics in my gallary.
