Sponsored by: CARiD
Lift-Level or What?????
Old Jun 22, 2007 | 11:11 PM
magoo304's Avatar
I have an 07 F150 XL reg cab 4.2L 5 spd. OEM Hankook tires P235/70R17 and OEM steel wheels.
I measured from the fender to the ground. 36 1/2" front and 37" rear. I assume that all trucks don't need leveling? The OEM tires are 30". So if I went to a 33" I would gain 1 1/2".( I want to stay with 17" wheels) What would be the best way to lift another 1 1/2" to 2 1/2"?? Body lift, or suspension lift, or ???
I won't be doing this right away. I have other things I want first as I get the money to do them. I just like having things all figured out.
Old Jun 23, 2007 | 10:21 AM
wandell's Avatar
I'd add a 2 or 2.5 inch Autospring leveling kit if you want to run 33's.
Old Jun 23, 2007 | 08:13 PM
magoo304's Avatar
Wandell Does the 2" leveling kit just raise the front?? If so do I need 1 1/2" blocks in the rear to keep it level? Or did I measure wrong?
Old Jun 23, 2007 | 09:48 PM
wandell's Avatar
Yeah, the AS kit just raises the front. Whether or not you raise the rear is just personal preference. I think a 2 inch AS kit would make your truck sit just about perfectly level.
Old Jun 24, 2007 | 02:57 PM
magoo304's Avatar
Thanks wandell. It seems that you are one of the most knowledgeable on here. If you don't care when it gets closer to me doing this I might pick your brain some more.
Old Jun 24, 2007 | 03:51 PM
wandell's Avatar
That's what this site is all about brother!!
