Sponsored by: CARiD
2006 STX 2wd ques.
Old Jun 14, 2007 | 02:08 PM
Joseph_73's Avatar
Question 2006 STX 2wd ques.
Ok.. Trying to draw on the vast pool of knowledge here.. I have an 06 STX SCAB 2wd. I would like to fit a set of 20's with tire size 275-55-20. I am pretty sure that I will have to do a 2.5in Front end levelling kit. I guess my other question is.. What AAL can I use to give the truck the clearance I need? Is there a specific lift I need in the back to clear those tires? Or would the trucks rear end ride be sufficient? If I am off base please let me know.. I am currently running stock tires 255/65/17.. Thanks in advance..
Old Jun 14, 2007 | 03:21 PM
omega1's Avatar
A friend of mine has 22's on his 06 quad cab. He didnt have to use any spacers or a leveling kit either. It clears fine and not rubbing.
Old Jun 14, 2007 | 08:38 PM
clar's Avatar
off subject what is a scab
2006 STX step side
ProComp 6" 3inch blocks and a add a leaf
steering stabilizer
cat back 3inch exaust into4" tip
Old Jun 14, 2007 | 08:46 PM
Budha05STX's Avatar
2006 STX step side
steering stabilizer
scab is a supercab and screw would be a supercrew.
Old Jun 14, 2007 | 10:51 PM
mt_b8's Avatar
My 4x2 came stock with 275/55/20's, you shouldn't have to do anything to your suspension to fit those tires.
Old Jun 14, 2007 | 11:11 PM
'06STX's Avatar
Here's my 2006 STX with 275/55/20's. Plenty of room, actually a little to much room in the rear for me, but no rubbing in the front fully turned. Inches to spare. Stock suspension.
Old Jun 14, 2007 | 11:22 PM
wandell's Avatar
Are you going with an off road tire or a street tire?
Old Jun 15, 2007 | 07:59 AM
Joseph_73's Avatar
I was thinking about Pirelli Scorpion ATRs. Not as aggressive as an MT but moreso than a regular street tire..
Old Jun 15, 2007 | 12:51 PM
wandell's Avatar
I'd go with a 305/55-20 (33x12.50) tire and a leveling kit personally. Also, look at the Nitto Terra Grapplers, Toyo AT's and the BFG AT KO's. I've just heard a couple of negative comments on the Pirelli ATR's.
Old Jun 15, 2007 | 01:03 PM
FoMoCoFan17's Avatar
x2
Old Jun 15, 2007 | 04:01 PM
Joseph_73's Avatar
Thaks for the responses.. I especially appreciate the opinions on the tires.. TireRack.com had the Pirellis rated very high. I will have to explore more of these options..
Old Jun 15, 2007 | 08:27 PM
clar's Avatar
35+12+5 Pro Comp All Terrain
