Sponsored by: CARiD
i need help!
Old Jun 10, 2007 | 08:55 PM
boguester's Avatar
Question i need help!
I have a 1999 f150 2wd extended cab and i am wondering what size lift I should get and if getting a lift kit at all would look good on my truck because the 1999 models look sorta long. well thanks and plez
Old Jun 10, 2007 | 09:03 PM
wandell's Avatar
Lifting a truck makes a truck look shorter. You have a ton of options for the 97-03 F-150 4x2's. You are only limited by the amount of money you want to spend. I would suggest going with a 6 inch Fabtech lift and some 33's or 35's.
Old Jun 10, 2007 | 09:14 PM
boguester's Avatar
got any pics? my price range is as cheap as possible
Old Jun 10, 2007 | 09:22 PM
wandell's Avatar
Sorry, I have a 4x4. If cost is an issue, I'd suggest a 3 inch Performance Accessories body lift kit and a set of Doestch 3 inch lift spindles. You can then add a lift block to the rear to get the height you want.
Old Jun 10, 2007 | 10:09 PM
boguester's Avatar
thanks
