Sponsored by: CARiD
upper control arms
Old Jun 9, 2007 | 09:56 PM
nordvik72's Avatar
upper control arms
I just got some new fabtech control arms and they could be a little longer than stock. I dont think a half of a inch or so will throw my camber off that much and im thinking if it does i could use a adjustable coil spring adapter to maybe correct the angle a bit! Is there anyone out there that can help me with this i emailed the guy at fabtech he really didnt help much. please help!!!
Old Jun 10, 2007 | 04:38 PM
wandell's Avatar
I think you are right. I believe they are longer than stock. This is so the camber can be adjusted to OEM specs if you add lift coils or coilspring spacers (which I assume you have one or the other). I would suggest adding a camber kit when you install them just in case you need it.
Old Jun 10, 2007 | 09:48 PM
nordvik72's Avatar
does fabtech offer that kit??
Old Jun 10, 2007 | 10:40 PM
wandell's Avatar
I don't know. You can pick up adjustable camber bolts at most parts stores for around $40.
