35x13.50-18 w 3" body lift?
Originally Posted by SCREWKR
This might have been covered but I couldnt find it through the search. Can you squeez a 35x13.50 under a 2002 4x4 on an aftermarket rim with a 3" body lift without too much trouble? Or would I need to go 12.50?
with the 3 inch body lift you shouldnt have any problems at all...on the 4x4 you can fit a 35x12.5 on the stock wheel without the lift if you crank on your torsion bars a little. with the 3 inch body you should be able to fit it without much work, maybe crank the torsion bars slightly or trim the edge of the fender/valance. i think wandell has been running a 35 on his with the 3 inch body for a while...as long as your rim isnt enormously wide you should be fine..
