Sponsored by: CARiD
Proof of 2.5" AS potential problem!!
Old May 22, 2007 | 07:58 PM
Tuchy3's Avatar
Originally Posted by BrockH
Next Question...if you need to add the new upper control arms with the 2.5" leveling kit. What about the 2" AS? Obvisouly it will sit about 1/2" lower and would lessen the angle on the ball joints. Would changing the 2.5" down to the 2" be better? It seem to be about 1/2 the cost of puttig new upper control arms on. Camburg wants $550.00 for the parts.
You do have a point and i didnt look to far into it yet but i do remember reading a post about the read lift leveling kit and that its about a 3" lift total so im thinking that by going with the ready lift then it wont be such a bad idea to purchase new uppers. Still looking into it and any more information about it would be great!!
Old May 22, 2007 | 09:36 PM
ameration's Avatar
I'm installing my 2.5" AS and 1.5" AAL on Thursday.
What about his idea of a bump stop? Any thoughts on if it woudl work or help at all?
Old May 22, 2007 | 10:16 PM
dirk upson's Avatar
i had the same set up 2.5 inch spacer and bilstein shocks, the shocks are not the cause of the problems. the shocks helped out the ride, and do not lift the truck. my angles were not that bad.
Old May 22, 2007 | 11:21 PM
jrbhc8's Avatar
I installed my autospring kit with the new shocks and it was still the same. When I put my stock shocks back on, the ride was perfect. I think I may have got a bad set of shocks or something.
jrbhc8
Old May 23, 2007 | 12:50 AM
RRT's Avatar
RRT
My brother in law and myself installed the 2" AS on his 04 and my 06 about a month ago. The angles on both trucks were not that bad. Both of our trucks sit almost completely level. The front is about 1/4" lower than the rear, but not noticable if you didn't know.
Old May 23, 2007 | 01:10 AM
deapee's Avatar
Thanks for the pics, you've made up my mind that I don't want anything to do with any spacer lift on my truck.
Old May 23, 2007 | 01:20 AM
BAKORACER's Avatar
I would suggest the limiting straps instead of the bumpstop. There is a reason why the baja racers use them...they work.
EDIT And if you are set on making your own thing then take apart a tow rope and make your own straps.
Old May 25, 2007 | 04:20 PM
ameration's Avatar
Here is a pic of my angles after installing the AS 2.5 kit yesterday. Not too severe looking at all.
Old May 27, 2007 | 02:45 PM
Satstalker's Avatar
I just got my 2.5 as and just wanted to no what your measurements were from the ground to top of wheel arch before and after install. I have about 2 3/4" difference from front to back so hopefully the 2.5 AS will work out just nice for a 2.5" lift. But i have read some peeps getting 3" lift from a 2.5 AS. This will look terrible if i get a 3" lift from mine. If this happens i will call AS and see about getting a 2" to replace the 2.5" lift.
Old May 27, 2007 | 02:57 PM
The angles look pretty severe to me.
Personally, I have a 2wd, and I had the 2" AS spacer on my truck without any problems, but I didn't like the angles it created, plus the UCA hit the coil spring at full suspension extension so I took it off before any problems could occur. I had the new offset design AS.
If I had a 4wd I'd be concerned about those angles and excessive wear.
Old May 27, 2007 | 07:38 PM
Satstalker's Avatar
Hmmmmm now im not sure if i should install my 2.5 AS now. Anybody got some long term use of these with a opinion.
Old May 27, 2007 | 08:16 PM
ameration's Avatar
Originally Posted by Satstalker
I just got my 2.5 as and just wanted to no what your measurements were from the ground to top of wheel arch before and after install.......
Measurements
Before (Stock):
Left Front - 37 3/8"
Right Front - 37 3/4"
Left Rear - 39 3/8"
Right Rear - 39 1/2"
To bottom of Left Mirror - 50"
To bottom of Right Mirror - 50 1/2"
After 2.5" AS and 1.5" AS AAL and alignment:
Left Front - 40"
Right Front - 40 1/4"
Left Rear - 40 7/8"
Right Rear - 41 1/4"
To bottom of Left Mirror - 52 3/8"
To bottom of Right Mirror - 52 5/8"
Also, a buddy of mine has one of these 2.5" leveling kits on his 2005 and has over 20k miles with no problems.
Old May 28, 2007 | 11:07 PM
lippens1588's Avatar
Ive got the same problem
Ive got the 2.5 leveling kit installed on my f150 but ive got the stock shocks and my angels are the same exact way ive had it aligned and it didnt change the angle a bit. Has anyone found a solution for this problem yet.
Old May 29, 2007 | 10:17 AM
hivoltagefx4's Avatar
I had my local Ford dealership install my AS 2.5 about 3 weeks after I bought my truck. My angles do not look anywhere near what yours are. Double check everything. I've had my AS 2.5 now closing in on 1 year and no issues at all. The truck rides great and sits nice and level.
Old May 30, 2007 | 12:44 PM
thebigbc's Avatar
okay, so i know what i am going to do. I am ordering some limiting straps this week. I think that will get rid of all my worries and me bottoming out my suspension.
