Sponsored by: CARiD
Space Pick?
Old May 6, 2007 | 02:13 PM
zambonimaxx's Avatar
Space Pick?
Hey guys...got another question for y'all. I have a 3.5 inch fabtech spindle lift sitting at my house right now...waiting for me to play with and I wanted to put 2 inch spring spacers on as well. I was just wondering what spacer y'all recomend as the best as far as durability (if its even an issue) wear and tearability (not really a word but I plan on bashing a bit) and rust resistance. Thanks guys!
~Phil
P.S. I forgot the R in Spacer for the title lol
Old May 6, 2007 | 03:50 PM
wandell's Avatar
I'd suggest the Daystar urethane spacers. I ran a set in my old Jeep for severel years.
Old May 6, 2007 | 08:21 PM
Thanks Wandell! If I have a 3.5 inch spindle lift, and then go with the 2.5 inch spacer, will there be issues with getting everything aligned? Or would it be safer to go with the 1.5 inch...I would greatly like to get the 6 inches of lift from this, BUT if it will be more issues than its worth, i'll go lower.
~Phil
Old May 6, 2007 | 08:50 PM
wandell's Avatar
You may have to install adjustable camber bolts with the 2.5 inch spacer lift to get your alignment correct. They are around $50 at most parts stores.
Old May 6, 2007 | 10:50 PM
Thanks Wandell! How hard are those to install, or should I just wait and have it all installed with the spindle lift?
~Phil
Old May 7, 2007 | 12:11 PM
wandell's Avatar
I'd do it all at one. The bolts replace the bolts that mount your a-arms.
