Sponsored by: CARiD
Lifts
Old Apr 22, 2007 | 03:38 PM
scsupercrew's Avatar
Question Lifts
Who sells a good suspension lift for a 02 supercrew, about a 4 inch. (kinda cheap!) Also what would that lift look like with 32s or 33s. How bad would that affect my MPG? thanks for the help.
Old Apr 22, 2007 | 04:28 PM
wandell's Avatar
4x4 or 4x2?
Old Apr 22, 2007 | 07:50 PM
Fx4. How good of mpg do you get with your truck? I would like to keep my 17inch wheels and maybe put a little bigger tire on, but not much, I just want it to look right with the lift and not too much fender well gap.
Old Apr 22, 2007 | 08:24 PM
wandell's Avatar
Your OEM 265/70-17 tires are basically a 32x10.50 tire, so you will want at least 33's with a lift. I have the 5.4 engine, 3.55 gears, 35 inch tires and get 13 mpg (combined city/highway). If you just want a little larger tire you could just crank up the torsion bars to level your truck and run some 285/70-17 (33x11.50), 295/70-17 (34x12.00) or 305/65-17 (33x12.50) tires.
Old Apr 22, 2007 | 11:52 PM
cranking the torsion bars wont put any strain on the truck anywhere will it, or wear the tires uneven?
Old Apr 23, 2007 | 12:26 PM
wandell's Avatar
You will need to have the front end alined afterwards. If you go too high, it will put the CV joints at a severe angle which will increase wear.
