Sponsored by: CARiD
Auto Spring Qestion
Old Apr 21, 2007 | 11:10 AM
cowboy_26's Avatar
Auto Spring Qestion
I am getting ready to order an AS kit for my '05 and dont know if i should go with a 2" or 2.5" is there any visual diffrence?
Old Apr 21, 2007 | 11:44 AM
hmfic's Avatar
From my expierence, it all depends on the truck. How much higher it the back than the front now? I netted over 3" with the 2.5" A.S. and a little over 2.5" with the 2" A.S.
Old Apr 22, 2007 | 05:55 AM
hazelbalz's Avatar
like hmfic said...the 2.5 will make the front sit level or just a little higher than the rear. I had a 2 and then went with the 2.5 and im very happy with it. It all depends on what you want. the 2 will be slightly lower than the rear but not by much.
Old Apr 22, 2007 | 11:35 AM
wxscpo's Avatar
Prior to my lift I had the AS 2.5" kit on my truck. Visually it sat perfectly level. From a measurement stand it sat slightly higher in the front, but was in no way noticable to the naked eye. I'd recommend the 2.5" kit.
Old Apr 22, 2007 | 11:48 AM
hmfic's Avatar
On my '05 FX4 I had, there was a bigger rake to it than my new '07 had.
I just put on a 2" AS on the KR and I am actually a slightly higher in the front now. You only can tell by measuring though.
Not sure on this, but I almost think that they changed something for '07 becasue all the trucks I saw at the dealer also did not appear to have as much rake to them as they have in the past..
Old Apr 22, 2007 | 02:12 PM
ameration's Avatar
My 07 FX4 is 2" lower in the front than the rear stock. So I would be at least 1" higher in the front using a 2.5" on my truck (net of 3"+). I am undecided what to do now as I do not know if I want to raise the rear also, at least not yet.
However, my buddy's 05 FX4 is .25" lower in the front that the rear with a 2.5" leveling kit so I really think that they did change something in the newer trucks.
Visually, all that I see is the lower A-Arms are not the bulky black steel that they used to be but I do not think that would have anything to do with it.
Old Apr 23, 2007 | 11:27 AM
Velvet Wheeler's Avatar
I put a 2" AS on my 07 and actually got 2.5". I am now dead level from front to back. Very happy with it.
Old Apr 23, 2007 | 01:23 PM
BroncoD's Avatar
go with the 2.5 kit. Looks great
