Popping Noise When Turning
I have a popping noise in the front end while i am backing and turning at the same time. it happens some times when i am pulling forward and turning as well. I can't tell where it is comming from. I have a 03 screw fx4. any ideas??????? It's not tires rubbing.
Doubletap this just a guess but I had the same problem; it drove me nuts for about a week! Finally figured out it was the alignment cams moving when I turned and while backing up with the wheel cranked. The alignment shop did not get the cams\bolts tight enough and swore there was something wrong with my lift (brought it back three times). My buddy and I used red loctite and tightened them up; no more popping noise!
[QUOTE=Tripyn69]Doubletap this just a guess but I had the same problem; it drove me nuts for about a week! Finally figured out it was the alignment cams moving when I turned and while backing up with the wheel cranked. The alignment shop did not get the cams\bolts tight enough and swore there was something wrong with my lift (brought it back three times). My buddy and I used red loctite and tightened them up; no more popping noise
I checked and made sure all was tight. Thanks anyway. P.S. I have a fx4, auto locking hubs
Tie rods, check them or have them checked. When checking, there should be NO internal movement, it should be able to twist but not anything else. Eliminate this part as a suspect, could be the CV or ball joint too. Don't be surprised if you're stabilizer bar end links are going or gone too.
got it fixed. i took it to a shop and they stated it was the left drivers side front axle shaft. they replaced it but it still popped. then he tightened all of the cross members and no more popping. it was popping from the frame and emitting to the very front of the truck. my advise is to tighten all up before replacing anything. this was the third shop i went to including a ford dealership.
