Is it ok to add a 2.0 or 2.5 spacer on a 6" coilover??
Hi there, I need help!
I am planing on putting 37" tire on my 2004 ford f-150. I have a 6" Pro Comp lift. My truck is a 2wd so is it safe to put a 2.0 or 2.5 spacer on my front coilover shocks?
Also.... do I did to buy new upper control arms since, I still have the factory arms?
Please help and thank you.
-Jason-
-Jason-
first off you have a procomp lift you cant stack spacers so no unless you have the procomp coilovers then yes but why not just crank up the coilovers..... your upper control arms should be fine unless you really want to upgrade... total chaos makes upper arms along with CST and a few other companys... but they are very expensive. i suggest a body lift or buy some coilovers and go that rought.
have fun trying to fit 37's under a 2wd, people with 8" lifts on a 4wd (about 2 inches higher than yours) have rubbing with them, so even if you could use the spacer, i don't think it would be a very good fit.
