Sponsored by: CARiD
4x4 VS. 4x2
Old Mar 23, 2007 | 02:39 PM
DracoF150's Avatar
4x4 VS. 4x2
Hey fellas can you tell me what are the difference in the front of these 2 vehicles??? As far as shock lengths, spring lengths and spring rates? How much higher does stock 4x4 sit compared to stock 4x2?
If you can put 4x4 shocks in 4x2 to get the 4x4 height?
Old Mar 23, 2007 | 03:47 PM
wandell's Avatar
The 04-07 4x4's sit about 2 inches taller than the 4x2's because of longer coilover shocks up front and a 2 inch lift block out back.
Old Mar 23, 2007 | 04:01 PM
DracoF150's Avatar
So the strut body is longer on the 4x4 than the 4x2? Or a combination of the strut and the coils? Will a 4x4 front strut fit in the 4x2?
Old Mar 23, 2007 | 04:16 PM
Speedy8's Avatar
heres a pic of it...i had it in another gallery
dont know if it helps but its some sort of visual
Old Mar 23, 2007 | 05:11 PM
DracoF150's Avatar
I figure the 4x4 strut and coil assemble will be different to comensate for the added weight of the 4x4, transfer case,axles,etc...the spring rates on the 4x4 may be higher than 4x2. Just thought if I can change out to 4x4 strut to gain the extra height...???
Old Mar 23, 2007 | 05:16 PM
ThumperMX113's Avatar
Why do people day and day again try to persue this route? It's a good idea in a sense but do you realize stock SUCKS!?
Get some Bilstein 5100s and be done with it. .
Old Mar 23, 2007 | 05:28 PM
DracoF150's Avatar
Thumper are the bilsteins 5100 Gonna help me get the extra height to obtain the 4x4 height? My goal is to be able to run 35" tires until I have enough for the RIZE 6" kit. But in the mean time trying to see what I can do to get the extra height???
Old Mar 23, 2007 | 05:46 PM
DracoF150's Avatar
Thumper???? If I get the bilsteins 5100 can I run the AS kit with it too??? That would be perfect. Sweet Info...Didn't know the 5100's comes with adjustable spring perch...
Old Mar 23, 2007 | 10:39 PM
wandell's Avatar
Yes, the Bilstiens have adjustable spring preload to give you some lift. However, you can't run them and a leveling kit. The angles would be too extreme and you probably couldn't even get the alignment close to specs.
Also DracoF150, do you have a 4x2? I don't think Rize makes a lift for 4x2's (but Fabtech and Pro Comp do).
