Sponsored by: CARiD
AS 2.5" and PA 3" BL
Old Mar 22, 2007 | 03:49 AM
wsnew's Avatar
Lightbulb AS 2.5" and PA 3" BL
Just a quick question for anyone. I have an 06 SCREW XLT 4x4. I was curious if I put a 3" Performance Accessories Body Lift on with the 2.5" leveling kit can I run 35x12.5x17's? I want someone to confirm this if possible before I order the wheels and put the lift on. Thanks. Here is the truck now.
Old Mar 22, 2007 | 08:46 AM
06STX4x4's Avatar
Yes you can, but you need to stick with stock rims or have aftermarket rims with very similiar specs.
Old Mar 22, 2007 | 08:55 AM
wsnew's Avatar
So 17x9's will be to much?
Old Mar 22, 2007 | 10:59 AM
06STX4x4's Avatar
I think you will be fine with that width, but the key factor will be backspacing. Factory is 5.5". I think 4.5" will cause some rubbing.
Old Mar 22, 2007 | 11:18 AM
bud8817's Avatar
wow wow i dont know if i would run a 17" wheel alot of the 17" wheels out there wont fit around our break calipers i would play it safe and do 18"s
Old Mar 22, 2007 | 12:04 PM
wandell's Avatar
Yes, you could fit 35's it a body lift and a leveling kit.
Old Mar 22, 2007 | 07:01 PM
wsnew's Avatar
The 17x9 is a Mickey Thompson Classic II with 5.5" of backspacing. From what I hear and read they will go around the calipers fine.
Old Mar 22, 2007 | 07:24 PM
TXFX4ONR's Avatar
I have a friend that has the 2.5 in daystar and 3 in P/A body lift on a 04 SCREW and is rolling 18x9 moto metal 951(4.5 in backspace) and 35x12.50/18 nitto mud grapplers and it doesnt rub at all. I myself am getting my 04 SCAB FX4 back from a shop in corpus christi. Already had the daystar and just had the 3in body lift installed. Next I will install rims and tires with the same specs(dont know what style yet) and I'll let you know how it turns out!
Old Mar 23, 2007 | 12:35 AM
wsnew's Avatar
Sounds good. I appreciate it.
