2" suspension lift??
That's one of the good things about a body lift, the ride quality is not affected. The Performance Accessories kits come complete with everything you need including steering extension, radiator shroud drop brackets, bumper relocation brackets, etc. I installed mine myself over a weekend. I don't offroad my truck, but a ton of people at FTW do some serious offroading with their trucks equipped with body lifts with no problems.
you cn crank the torsion bars as far as they will go, but jut remember the farther you go with them the less travel you will have in the front end as well as the ride will stiffen up. The aftermarket torsion bar keys that you were speaking of give you between 2"-2.5" but will stress the front end more than just cranking the torsion bars....so if your just lookinfor a way to fit a larger tire, it would be ok, but if your plannin on wheelin your truck, be careful with the torsion bar keys
Originally Posted by cowboy63645
how rough will the ride be with the torsion bars cranked though? And I know that after some time they will eventually settle back down and lose the fift from it....
