Sponsored by: CARiD
AS 2.5/UCA+Spring=Contact
Old Feb 11, 2007 | 09:47 AM
SuperSlabCab's Avatar
I was out last night adjusting my headlights after installing the AS 2.5, and I noticed that the UCA had hit the spring and chipped the paint, on both sides. That would mean that the front end came unloaded at bumps or transitions.
I cant say I heard any obvious noises, but contact is not necessarily a good thing.
Anybody have this happen, and if so, what should I adjust to stop this.
On a side note, the upper ball joint doesn't seem so out of whack underload-but it definitely looked odd up on the stands.
Old Feb 12, 2007 | 06:18 PM
05F150Tex's Avatar
I wonder if this is a common thing, as mine also has a rubbed off spot on both sides. Hopefully someone with more knowledge about this will chime in.
Old Feb 12, 2007 | 10:10 PM
One thing I did different than the instructions, is that I loosened the bolt and nut on both sides of the UCA, to get the UCA to seat on the tapered shaft.
If I didn't, I had to pry the UCA down, and that was a struggle.
Could it be that the tightened bolts kept the UCA tensioned, not allowing the UCA to come in contact with the spring?
That's a stretch.
The picture with my sig is the before shot, I have to clean the truck to take an after.
Old Feb 12, 2007 | 10:21 PM
wandell's Avatar
Autospring now builds their kits with a slight offset to eliminate this touching. It's not a big deal, as the spring only rubs when the suspension is a full droop.
Old Feb 12, 2007 | 10:56 PM
Are you saying the offset eliminates rubbing? Because my spacers are offset-and the rubbing is there.
Must of been worse?
Old Feb 12, 2007 | 11:01 PM
I had (took it off) a 2" AS spacer on my truck. The only time the knuckle touched the spring was when the shock was fully extended on jackstands, which could also happen while driving. I didn't like that very much. I guess that's why it's a cheaper lift.
wandell's Avatar
Right. I've heard members with the old design say they could hear the spring hit over large bump/dips when the suspension topped out.
Old Feb 13, 2007 | 07:19 AM
New Design. Hitting. Livable. Should have a fix.
Old Feb 17, 2007 | 12:29 AM
lastorms's Avatar
I'm glad too see a truck like mine. I got an '06 with the same set up..still stock. Can't wait to see some pics with your add-ons
Old Feb 17, 2007 | 08:14 AM
I've only had it for a month and a half.
the next mod is a diamond plate tailgate cover-the gate is a piece of tin.
