Sponsored by: CARiD
Easy body lift question
Old Feb 8, 2007 | 04:20 PM
jk007's Avatar
I had a 2000 f150 4x4 with a spray in bedliner so when I put the PA 3" body lift on it, the bed bolts were easy to get to. The truck has since been totaled so I'm looking at an 03 4x4 FX4 right now.
The 03 doesn't have a spray in bedliner, rather a regular plastic bedliner. Are these easy to take off to get to the bolts underneath if I was to lift this with the same 3" PA body lift? I forgot to check to see how much of a pain it would be with the regular bedliner as opposed to the spray in.
Thanks,
Old Feb 8, 2007 | 04:23 PM
Bryndon's Avatar
Depends on the brand how easy, but generally they aren't even fastened down - if you grab the rear edge in the middle and lift, it probably will just flex up. If so, just pull the edge out from under the rail and lift it out. If it doesn't lift easily, check for corner fasteners.
Easiest if you have an extra set of hands - once you've done a few it's easy to do alone, but for the first one get a friend.
Old Feb 8, 2007 | 04:24 PM
wandell's Avatar
The plastic drop in liner will pop right out. Much easier than cutting Line X or Rhino Liner.
