Sponsored by: CARiD
Just lifted!....now what do I do?
Old Feb 6, 2007 | 11:38 AM
AgirlsToy11's Avatar
I have an 06 2wd 4.6, 6" Fabtech, 35x13x18 Toyo AT. I'll have this truck for a while so I want to make it last. In order to put the least amount of stress on it but get the most out of it, what changes should I make?
Thank you!!
Old Feb 6, 2007 | 11:44 AM
ThumperMX113's Avatar
Gears.
Old Feb 6, 2007 | 11:47 AM
Bryndon's Avatar
Start with being gentle on it and changing fluids on schedule - those are the easiest and best ways to make one last a long time. General maintanence (right out of the owner's manual) including filters and checking tire pressure & rotating, etc.
What rear gears do you have? And transmission type (manual or auto)? With the bigger tires, it will depend what type of rear gears you have whether a gear change is in order.
Other than that... I'll bet a few more suggestions pop up.
Old Feb 6, 2007 | 12:56 PM
Ya I figured gears were first on the list. I have 3.73 ls. I guess I'll have to read up on it. Any idea of what that will cost? Thank u!
Old Feb 6, 2007 | 12:58 PM
pkent03F-150's Avatar
service regularly and itll last along time no doubt
Old Feb 6, 2007 | 01:11 PM
Bryndon's Avatar
It varies a lot around the country - check around your area. One caution, go to a shop that is experienced - possibly even the dealer. I've seen gears installed by shops that didn't know what they were doing - a buddy trusted "a local mechanic"... long story short, both gear setsa in his 4x4 were toast, inside 1,000 miles.
Old Feb 6, 2007 | 01:30 PM
bud8817's Avatar
i just got quoted for for $1200 but i have a 4x4 so probably half that.
Old Feb 6, 2007 | 01:47 PM
I'd say about $600-900.
Old Feb 7, 2007 | 01:57 AM
Gant's Avatar
im getting new gears in mine for 380.. 180 for the gears and 200 for them to set them up for me..
Old Feb 7, 2007 | 10:51 AM
Thank you!! I guess I have a lot of researching to do.
Old Feb 7, 2007 | 12:38 PM
Do F150's Float's Avatar
Mine's an '02 2wd, but i think it had the 373's in it too, we went 455's (Slightly over-geared, so you have to do the tuner to correct speedo & shift points) but it sure as hell picks up nice
Intake & exhaust are good too!
