Sponsored by: CARiD
Major problem installing AS 2.5
Old Feb 3, 2007 | 11:25 PM
TennesseeTritan's Avatar
Went to install my 2.5 spacers last night and ended up having to give up and put everything back to stock.
Absolutly could not get the 30mm bolt to break loose! Tried a socket on a breaker bar with about a 3 foot pipe on it and snapped the extension in 1/2!!!
Then I borrowed a compressor and impact wrech and it still wouldn't break loose! Has anyone else been as lucky as me to do such a simple install?
Old Feb 3, 2007 | 11:57 PM
FX4_Off_Road's Avatar
Oh yeah, the 30MM bitch, I broke a rachet & an extension I ended up using the harder 3/4" impact socket & extension and a 3 foot cheater with some liquid wrench. But she finely broke loose.. Don't let it kick ya ***, get back in there
Old Feb 4, 2007 | 08:20 AM
hivoltagefx4's Avatar
Ah yes! The joy of paying someone else to do mine!!!
Old Feb 4, 2007 | 08:23 AM
I finally whipped it! I got a bigger impact gun and got the job done. Got finished at 5 in the morning though Peeps who say this takes an hour and a half muct be talking about per side All I know is it's on and it looks a lot better, now time to save for tires and wheels
I finally whipped it! I got a bigger impact gun and got the job done. Got finished at 5 in the morning though Peeps who say this takes an hour and a half must be talking about per side All I know is it's on and it looks a lot better, now time to save for tires and wheels
Old Feb 4, 2007 | 08:34 AM
That's good. Funny thing is mine came loose with a 1/2" ratchet only.
Old Feb 4, 2007 | 08:53 AM
05F150Tex's Avatar
I think its a fairly common problem. Mine was the same way on the first side. I had quite a few things to say to that dang nut (I'm being mild here!) but finally got the first one loose. First side took just under two hours to put the spacer in--second side only took about 30 min. thank goodness!
Well worth the effort in the end, though!
Old Feb 4, 2007 | 09:14 AM
wandell's Avatar
Sometimes Ford gets carried away with Loctite. I know they did on my body bolts.
Old Feb 4, 2007 | 08:18 PM
Yeah, I'd rather know it's put together too good than not good enough,I guess. But I do know I'm not about to tackle a body lift, I'll just have to pay someone. Thanks for the help though this site rocks
Old Feb 5, 2007 | 01:06 AM
spinnintires's Avatar
if your having tons of problems, take a can of liquid wrench of wd40 with you everywhere, and the day before install everytime you are near your truck spray the bolt, it will loosen it up, and spray right before attemtping to break it, it should still be tough, but i got it off, with only a breaker bar, see what you can do, shouldnt be a problem, and good luck
Old Feb 5, 2007 | 02:26 PM
bud8817's Avatar
that sux i never had any major issues while installing mine..... and it took me an hour and a half tops!!!
Old Feb 5, 2007 | 02:49 PM
funtuff's Avatar
hivoltagefx4,
I work in your area. Where did you have your AS 2.5 installed and how much did it cost. I'm looking for a place to have mine installed with a AAL.
Old Feb 5, 2007 | 03:19 PM
djh1121's Avatar
Man, you can say that again... When I installed my 6" lift I could not believe how tight some of the nuts/bolts were...
Old Feb 5, 2007 | 04:36 PM
-TXF150-'s Avatar
Were u using an inexpensive walmart or home depot impact wrench?? Cuz I have done a cople of AS installs, and my MAC impact takes them out with no problem..
Old Feb 6, 2007 | 09:03 PM
Hokieron's Avatar
Thumbs up
If there is clearance there and no bushings, in the future take a torch and heat the nut up, it will make removing it a lot easier.
