Shocks
Oh and what do they mean when they say with/without 7700 gvw models? And my dad, his friend, and me were going to install my spindles this weekend, but the weather is not permitting, and plus I have a soccer oturnament. I called 4 wheel parts and they said they can't install the spindles and a coil spacer. Any reason for that, to my understanding they will work together.
4Wheel Parts is infamous for giving misinformation. You should be fine with spindles and spacers. You may need a camber kit to get your alignment correct with that combo. As for the shocks, the RSX are supposed to have speed sensitive valving I believe.
Meaning that it senses how fast you are traveling and adjusts? So if thats true then wouldn't they have the advantage over the 9000 since you don't have to adjust them. And I found another shop to do the work while im gone.
