Sponsored by: CARiD
Bigger than 6" for 97-03?
Old Jan 7, 2007 | 03:22 AM
TurboGoKart's Avatar
Does anyone make a 8, 10, or 12 inch lift kit for the F150, 97-03 body style? I know everyone talks about rize, but that's for the 04's and newer.
Old Jan 7, 2007 | 09:09 AM
wandell's Avatar
Full Throttle and Bulletproof make some huge lifts for our trucks. Most people tend to run 6 inch suspension lifts with a 3 inch body lift however.
Old Jan 7, 2007 | 09:45 AM
Is there a reason behind doing it w/a body lift rather than all in the suspension? Only thing I can think of might be price.
Old Jan 7, 2007 | 09:55 AM
wandell's Avatar
I'm not sure of their prices. Part of it is probably the bad reputation given to huge IFS lift kits by Whiplash. Part of it is because a 1/2 ton truck can only handle a tire so big before parts start breaking regularly because of the added stress added by huge tires.
bigtruck311's Avatar
from what i have read and heard the larger lifts (8+ inches) put the front cv shafts at a extreem angle and cause wear, also for offroading purposes it doesnt handle as well and the half shafts (cvs) have a tendicy to snap offroading, they are more for looks, if you are biulding a mall crawler go for it, if you want to do some heavy offroading, go with a 6" fabteck and a 3" PA body lift.
Old Jan 7, 2007 | 05:16 PM
sean_somer's Avatar
agree
anyone that offroads with a 97-03 150 down here uses a 6" fabtech & a 3" PA Body Lift (& Bilstein 5100/50s)
or if they have a larger budget they use the Rock Krawler 6" Coilover Conversion kit
Old Jan 8, 2007 | 12:24 AM
Thanks for this info! Definately all good info. I pretty much had planned on only doing a 6" susp. lift, but I was just curious about the higher sizes.
