Sponsored by: CARiD
Rize Again
Old Dec 23, 2006 | 10:07 AM
ALL4FORD's Avatar
Rize Again
Well I think I am going to go and do it. I already ordered the 20's Gear Alloy Locker and I wanted to order a set of Pit Bull tires 39.5x16.50R20. I was wondering if the 8" RIZE kit with a 2" leveling spacer will clear these and will the angles of the CV's be to off. If not I will go with 38x15.50R20 TRXUSS. I mostly do driving on paved roads but every now and then a little beach use.
can some one with RIZE knowledge help me out
Old Dec 23, 2006 | 02:17 PM
wandell's Avatar
Man, I just don't know. We don't have anyone running a tire that big on an 04-07.
Old Dec 23, 2006 | 02:32 PM
ALL4FORD's Avatar
Always have to be a bigger one....
I think they will fit in theory, if I'm not mistaken PATOSHEA has 38x15.50R18 and a RIZE 8" and had no rubbing and with a tire 1.5" taller and a 2" inch spring "should" fit
What about the CV angles?
Old Dec 23, 2006 | 04:15 PM
bud8817's Avatar
should fit perfect..... thats a wid *** tire though wow!!!! but the angle should be fine rize puts the angle better then stock with there lift so the spacer should work great. just wondering why not just get the 12" lift from Rize? the tires would fit forsure then....
Old Dec 23, 2006 | 04:19 PM
allrsdup's Avatar
that will not fit patshea rubs with his 38's and i rub with 37's a little bit on turns with big bumps. u want to essentially go with a 40" tire and 12" is the recommended height for that.
Old Dec 23, 2006 | 04:40 PM
ALL4FORD's Avatar
where does PATOSHEA rub and is it trimable rubbing or rip off the fender rubbing. And the RIZE 12" is around $4500 and I can get the 8" for $2200 and a 2" Spacer for $80 so this means 10" lift for $2280. So if I can get away with a little trimming I'm good
Old Dec 23, 2006 | 04:57 PM
06FX4's Avatar
get a 3" BL ontop the rize and you will be good!
Old Dec 23, 2006 | 10:18 PM
Truspeeder205's Avatar
Hey where did u get such a good deal on the rize 8"... im just now getting reaady to buy it too lemme know where u got such a good deal on it ...
Old Dec 25, 2006 | 01:25 AM
allrsdup's Avatar
u will rub on the inside of the fender bottom part. i would do a 3" body lift on top of that if u are set on 40's but i dont see y u need 40's 37 38" are plenty big enough of a tire.
Old Dec 26, 2006 | 10:29 AM
ALL4FORD's Avatar
BIGGER IS BETTER
I am just use to it, my two previous trucks had 44" one had Boggers and the other **** Cepek Fun Country
79 Ford 44" Boggers
1996 F350 with 44" **** Cepek's
Old Dec 26, 2006 | 05:41 PM
captain morgan8's Avatar
Yep.
Old Jan 2, 2007 | 05:53 PM
TNoff's Avatar
Yeah that's a good price for the Rize. I'm hearing 2400 around here.
Old Jan 8, 2007 | 08:05 PM
torturekilla's Avatar
where the **** do you get a rize for 2200$$$$$$$ can you plz give me the link or # to the place you got it at cuz i really want that lift...
