Sponsored by: CARiD
2.5 spacer and backspacing ?'s
Old Dec 18, 2006 | 05:57 PM
tbrracer's Avatar
With a 2.5 leveling kit what is the backspacing have to be on the rim I would like to stay with 17"
maybe 17x8? 4.5bs will that work?
Or with a skyjacker 3" coilover what backspacing ?
Thanks guys
Rick
Old Dec 18, 2006 | 06:00 PM
wandell's Avatar
I assume you are talking about a 04-07 F-150. THe OEM wheels have 5.5 inches of backspacing. I would try to stay close to that. I don't think either lift requires a certain backspacing. Also, I'd go with the leveling kit over the Skyjacker coilovers. 3 inches is just too much lift without drop down brackets. You will go through ball joints and CV joints quickly with the Skyjacker.
Old Dec 18, 2006 | 07:28 PM
tbrracer's Avatar
duh very sorry yes 06 f150 2wd
thanks
So 4.5bs is not enough can you explain more bs means the wheels stick out less correct? or the other way around?
Rick
Old Dec 18, 2006 | 07:34 PM
josho66's Avatar
thanks
Rick
The more backspacing, the less they will stick out. From what wandell has told me 5.5 or 6.0 is the better size. Some people like to have 5 that will stick them out about 1.5 to 2.0 over stock I believe.
Old Dec 23, 2006 | 09:12 AM
catfishunter72's Avatar
I just put level on mine, used stock 17 wheels with 185/70/17 work out great
