Sponsored by: CARiD
Ball Joints
Old Dec 2, 2006 | 01:38 PM
mlsman23's Avatar
Ball Joints
How do i take out/put the new ones back in. And what is a good brand to go with? They will be going on when I do my spindle lift.
Old Dec 2, 2006 | 06:40 PM
Yankee7985's Avatar
#1. Get Moog ball joints. You can grease them.
#2. Get camber kits for the upper control arm.
#3. For the upper ball joint, the entire control arm has to be replaced.
#4. The lower ball joint has a C-Clip that needs to be removed first. Once this is done, you beat on the ball joint with a BFH. Installation is reverse, minus the beating with the hammer.
Old Dec 2, 2006 | 07:13 PM
mlsman23's Avatar
I have an 02 so is it different on the new body's? I thought that they might have to be pressed in.
Old Dec 2, 2006 | 08:03 PM
paulh's Avatar
I had a question for the upper control arm I didnt know you had to have a camber kit.I got the camber kit installed at the ford dealer do I still need to get the camber kit?Also I have the 7.5 fabtech on it and does the kit rid the camber kit?Thanks for the info.
Old Dec 4, 2006 | 10:52 PM
Yankee7985's Avatar
If you already have the camber kits, don't worry. Just put them back in when you replace the upper control arm. I used a floor jack to press the lower one in. Once I got it started I used a jack to apply pressure.
