Sponsored by: CARiD
good lift for and 03'
Old Nov 8, 2006 | 05:45 PM
RUNoverIT71's Avatar
I have a 2003 flareside sport with the short bed reg. cab , Its already pretty high I mean I'm 6 5' and I still have to hop in it , I wanna decent lift that won't look stupid on such a short truck , I was thinking about doing tires between 33-35 inches and just doing a 3inch body or suspension lift , but does anyone know how it might look if i through a 3inch suspension along with a 3 inch body lift ? I really would like to know how that would look but I'm just looking for advice because i haven't seen a lot of these trucks lifted , my style truck that is. thanks guys , dave
Old Nov 8, 2006 | 05:58 PM
wandell's Avatar
A 3 inch body lift or a 4 to 6 inch suspension lift will allow you to fit 35x12.50's on a 10 inch wide wheel. If you install a suspension lift, I'd suggest the 6 inch Fabtech or 5 inch RCD lift.
Old Nov 8, 2006 | 06:01 PM
Yea that 5 inch rcd would be Ideal.. but the cost may be an issue , can I use my stock rims if I put 35's ? , because If I go wider on the tires I'm going to need a wider rim to fit it right ?
Old Nov 8, 2006 | 06:15 PM
wandell's Avatar
Several members here have run 12.50 inch wide (305 and 315mm) wide tires on the OEM 7.5 inch wide wheels with no problems.
Old Nov 8, 2006 | 06:24 PM
what do you think the lift alone will run me , is there any way I could keep it below 2 grand
Old Nov 8, 2006 | 06:33 PM
Fordwitflows's Avatar
I have a 3" Body lift and 34's to give you an idea. After the winter I will be adding a 6" fabtech susp lift and 37" tires. A body lifts going to run you $200 bucks and a susp lift such as a 6" susp lifts gonna cost you anywhere frome $1500-$2000 depending on where you get it. If you not able to do the intall yourself labor is going to depend on your area and who does it. I was quoted $500 for body lift and $800 for susp lift at my local susp place.
