Body Lift Kits and Leveling Kits
Well I am planning on raising the body of my truck atleast 3" and I have noticed alot of People posting things about a Leveling Kit. I was wondering what a Leveling kit will do to my truck and if it will work if I put a 3" lift kit and a leveling kit on it. I would like to also see some pictures of truck with a leveling kit and a Body lift on it..Thanks
okay- im not tooo sure i know of anyone with a leveling kit, and a body lift, there are probably a couple, but heres what a leveling kit does...
this is my truck when it was stock:
this is my truck the day i put on my 2.5" AutoSpring leveling kit:
with a leveling kit installed you as a 2wd can fit 33"-34"MAX overall tire size
with a leveling kit, and a body lift, you as a 2wd can fit 35's
no problem- not that i can think of- i would suggest searching both this forum, and maybe the 04-07 forum for some info about body lifts- there are some pretty knowlegable guys around here- good luck man
y would u run into any problems? ull be fine. ur truck with the leveling kit and body lift will probably be about an {1"} or {1-1/2"} higher than baloguk. so if u want a lift i recomend a suspension lift. I.M.O
